First port of call is always going to be getting a good code reader on it and seeing what the ECU's
It's a Mazda 3 2015 skyactive.What car is it?
A friend has a set of gauges I can borrow so I'll tap him up and check the pressures. Thanks.System pressure is the first check as mentioned above, what comes next is entirely dependent upon that. Bear in mind that the pressure is temperature dependent, on a system at 20deg.C. Ambient and static (compressor not running) using R134 refrigerant you should see around 4-6 Bar, anything less than 3 and the pressure sensor or switch will be preventing system operation. If you're getting pressure in the correct range, then diagnostic code read is the next step, if it has a sensor rather than switch, read the live value to check for correct operation.
The AC compressor will typically be controlled by the engine ECU, so you'll usually find AC pressure readings there.I have a Topdon Artidiag 500 but having just looked at the specs on it I'm not sure it covers AC.
In a workshop environment, a pure pressure check isn't reliable as it doesn't really indicate how much refrigerant is in the system. Ideally you'd recover the refrigerant and compare the weight to that specified but in a DIY (and aircon is no longer a DIY task given the legal requirement for F-Gas certification) situation, a pressure measurement (for which you really should have F-Gas certification as you're opening the refrigerant circuit) is a very rough indicator, nothing more.
And yes, I know fleabay is awash with 'top-up cans', it's only a matter of time before someone cottons on and they're prohibited from sale.
A 2015 Mazda may well use R1234-YF, in which case, the pressure values will be slightly lower, but the 3Bar minimum will be the same.
If you have access to gauges, this may be of use.
R134a Pressure Gauge Readings
How to interpret R134a pressure gauges. Understanding air conditioning gauges.www.vehicleairconservices.com
Is that from eating sprouts or beans,?+1
(even I have a F gas ticket now!)
It's cabbage up his way isn't it?Is that from eating sprouts or beans,?
Exactly this, you will usually see low pressure on air conditioning circuit in the fault list and also how many bar/mbar is in the system on the live data output. It doesnt have to have some, it has to have over a set amount the ecu checks for before turning the clutch on with a modern setup. If you have a system that sometimes works and sometimes doesnt, it can be the gas pressure right near this trigger value and flip flopping with conditions on the day...You need to know how much pressure is in the system for a start, because "some" might not be enough.
First port of call is always going to be getting a good code reader on it and seeing what the ECU's are actually seeing. Without that I'd think your on a hiding to nowhere.
Thanks again.
He's just messaged me saying he's taking it to his girlfriend's garage for them to have a look.
Hopefully it's just low on gas...
