I get what your meaning I think, a tractor sitting at 2000 rpm 10 hours a day for 5 days, lets say a car does 60 mph at 2000 rpm for easy counting, does that reflect to engine wear the same as a car doing 600 miles a day, does that equate to the same as 3000 miles in engine wear.What do you think the conversion is in the UK. I thought about 30 but looking online it's anywhere from 24 to 50.
I serviced a tractor this week that had just hit 20,000 hour's and wondered what it was in miles.
I’d say that’s about 3-4 thousand miles equivalent it was a car engine at 100 hoursI get what your meaning I think, a tractor sitting at 2000 rpm 10 hours a day for 5 days, lets say a car does 60 mph at 2000 rpm for easy counting, does that reflect to engine wear the same as a car doing 600 miles a day, does that equate to the same as 3000 miles in engine wear.
The reason I wondered this is I have some Godiva fire pumps with ford CVH engines 1.6l and some had less than 100 hours run time.
Same on the school run, they sit for an hour every school day outside mine keeping warm or cool depending on the weather reading a book.thats why you dont buy top end cars of the old bill. they sit in laybys for hours on end engine running without clocking the miles up so look a good buy for the lower milage
I remember seeing half a dozen ex-plod X5s up for auction - average mileage 65-70k. They'd all had replacement engines at around 40k, so not long before they'd be needing another one...thats why you dont buy top end cars of the old bill. they sit in laybys for hours on end engine running without clocking the miles up so look a good buy for the lower milage
So that makes a 20k hour tractor 560,000 miles.my vans speed average for the last 7000 miles is 28mph. i suspect a tractor will be nearer 10.
You’d be knocking on the door of a quarter of a million miles equivalent on a road going vehicle with that amount of hours.I don’t think there is an easy way to convert tractor engine hours into miles, our last forestry tractor was all done after an extremely hard going 15000 hours, the same hours with the same tractor towing a mower about would be nothing for it.
Bob
Older tractors had a mechanically driven tachometer and hour clock so higher rpm meant more hours. But modern one's are just timers.How do engine hours relate to rpm?
This^^^^^Older tractors had a mechanically driven tachometer and hour clock so higher rpm meant more hours. But modern one's are just timers.
I cant remember if it was the ford 10 or 40 series, maybe both had an egg timer symbol on the rev counter at approx 1500 rpm from memory, this was hours to timed hours, I timed it one night with the needle on that symbol just to see.This^^^^^
Some older tractors could clock up an hour in less than an hour if working really hard cultivating seedbeds etc. But take 1.5-2 hours to clock an hour on light jobs. Gave a more accurate view of the work it had actually done.
Used to count roughly that 1000 hours on a tractor was equivalent to 10,000 miles in a car.
But thinking about it my 18 y o car has over 150k miles on it and tells me the average speed over it's lifetime is 30mph so someone has sat in the seat for 5000 hours. Which is just run in on a tractor or for the same age 277 hours a year.
Are you wondering about running gear wear miles or engine wear in miles,What do you think the conversion is in the UK. I thought about 30 but looking online it's anywhere from 24 to 50.
IIRC seeing somewhere that on the mechanical ones (like my Ford 7610) that "true hours" was at PTO speed.I cant remember if it was the ford 10 or 40 series, maybe both had an egg timer symbol on the rev counter at approx 1500 rpm from memory, this was hours to timed hours, I timed it one night with the needle on that symbol just to see.
