chunkolini
celebrity artiste
- Swansea
I have been asked to make a welsh dragon and we discussed using corten steel to avoid corrosion damage over time
The customer likes the Corten bridges on the A483 over Abergavenny they are looking fantastic after a few years in the Welsh sunshine.
So working corten
welding? can you use mild steel mig wire? Im sure I heard that this is ok
sheet first. the wings and body will be made of sheet probably 1.6mm. Does it cut and bend similarly to mild steel or is it harder to form? I have plasma cutter, angle grinders and hand held power shears and a set of 4ft rollers for curves
Plan A is to make a hollow body using this sort of structure. Basically two sheets cut to size with an internal frame and then wise strips welded around the edges to give a solid looking body.
Plan B (slowly becoming Plan A)
is build a structure of round bars and fill it in with small panels to give a structure like this
bars and strips.
ive seen round bar for sale but no flat strip. Id be looking for 10mm round bar and 30x5mm strip.
would they both have similar properties to mild steel? for cold working. I cant see many problems with the round bar but the strip? would it bend along it's flat side like this? of would it just refuse to bend?
to date I've always used hot rolled mild steel with no problems
can anybody recommend a supplier? I've found sheets of 1.5mm for £176 at Buy Metal Online pricey but seems ok for a posh product
but no strips so far.
I think thats enough for starters
Cheers all.
So working corten
bars and strips.
Cheers all.
