The pix looks like the contact tip is not aligned with the rest of the gun ?
Or loose from the socket.
I would like to see an exploded diagram of this.On this nozzle, the shroud hold the contact tip against the gun. I don’t think I could run it without the shroud
I am having trouble imagining it as well. If the nozzle insulator comes in to hold the contact tip, how does the gas get out? Is it slotted? Is it FCAW-S only?I would like to see an exploded diagram of this.
Perhaps I am just unimaginative - apparently so, here are the catalogue items.
That's not how my ESAB torch works.
Jack
So the shroud is live?I have the same set up in my thermal arc 181i fabricator, the shroud holes the contact tip in place, there is a ring inside the shroud with a series of holes allowing the gas to pass through which also holds the tip in place.
Chris
Must be an insulator in there some where, have a look yourself.So the shroud is live?
I wouldn't think so. The parts list doesn't show inside the nozzle but given the metal thickness and the imprints around the outside of the nozzle, there must be an insulator inside.So the shroud is live?
