Used TST dry break quick connects - seem a reasonably priced quality product. Not quite sure where we source them as yet - currently on test after I discovered them to replace very similar, but vastly more expensive, Norgren items.
www.actionsealtite.com
then i found out why . it was still full of air and the comp had cut out and i hadnt shut the ball valve off so no chance of getting them apart when in use. they press together and turn and double click so no chance of knocking them and un coupling in useI used to do some work for a small heritage railway, which did not have a particularly strong safety culture...Ive seen one break away…..its not pleasant, hence why crows foot connectors are banned in some industries.
Never could convince them of the merits of following safe rigging practices, or fitting flashback arrestors to their acetylene cylinders though...
i aquired a pair for my bottlesWhen I was younger I used to scoff at the idea of flashback arrestor because it was said that they stop any fire burning back to the regulator. Then I did some training and found out that it travels up the pipe at around the speed of sound.
ive had a few burn backs and tripped the arrestors twice . god help if i hadnt fitted them .a mate uses his without them
wouldnt care i gave him a set to put on and he hasnt bothered
just been lucky i supposeInteresting.I used to do some work for a small heritage railway, which did not have a particularly strong safety culture...
One of the few rigourously observed safety rules was "Claw fittings must be pinned and tethered".
When I asked why that was so important to them, one of the old guys just went:
"do thee want half a pound of brass whipped into y' skull at 90 miles an hour lad, cos tha' **Language**ing dunt"
Interesting.
Was watching a video on U-toob, showing hump yard operations, they would unhook the coupler (throw the lever), and as the cars separated, the glad hands pulled themselves off.
250 psi steam.....never knew that.This was more in the workshops and sheds, I didn't deal with the trackside stuff much because I'm not a big enough train nerd...
Although all the trains they ran had steam brakes... So unlike vacuum or air not something that you could just allow to disconnect itself without a self-sealing coupler.
250psi steam being several orders of magnitude scarier than 150psi air and all.
Not a particularly common system (for good reason) they also had vacuum brakes on some carriages.250 psi steam.....never knew that.
I thought there was either George (Westinghouse) with 100 psi air, or the Vacuum system (like for India Rail)
interesting.
Yes, nowadays with trains over 100-120 cars, by the time you got to the end, you'd have nothing if it was steam.Not a particularly common system (for good reason) they also had vacuum brakes on some carriages.
Yes, and direct acting too, so fail deadly, not fail safe.Yes, nowadays with trains over 100-120 cars, by the time you got to the end, you'd have nothing if it was steam.
