Yes I had a good connection, It doesn’t help when you can’t connect directly onto the battery, one because it’s hidden under an air pump but even if it was accessible you can’t get the leads onto the posts due to surrounding plastic lead housings. Those remote connection points are fine for jump leads or a conventional battery pack because you can connect them and leave it for a few minutes before trying to start but these Noco boosters don’t work like that they try to produce a large boost over a short time period.I have found even with the bigger ones you absolutely need to make sure they get a good connection. I've had where it feels like they are doing nothing, adjust the clamp and they work really well.
That may not be the case for a GB50 though.
I have a GB70 and a GB150. Used the GB150 to start my lads Massey 3080 with a 6 cyl perkins quite a few times, when new they ran 2 batteries to get the cranking amps but his has an 1100CCA battery. If you want regular use out of them then it's worth having the fast charger but that's another £50.
I'v had the GB150 for probably 3 years and it's had quite a lot of use, often starting stuff that has been sat around in the yard for years. It doesn't have the same amount of power it had when I first got it. It's a shame you can't get new batteries for them.
Which Snap On unit do you have? I've been looking a Portable Power 1800RC recently as I like the fact you can buy all of the parts for them even if you have a 20 year old one. They are same unit Snap On used to supply.
Our new one is a Lithium Ion Jobby, we have a Portable Power as well (bought from Snap-on a long while back).
Someone at work bust the Portable Power (dropped a bike lift on the lead connection) and they supplied all the bits to repair it, very helpful company to deal with and great price on parts. Ours isn't far off 15 years old.
Excellent, that's good to hear. I did look at prices on replacement batteries for the Portable Power unit and amazingly the Portable Power were no more money than aftermarket suppliers and at least you know it will be 100% right.
Does the Portable Power unit start most stuff? I'm assuming it does given you've had it so long.
Doesn't sound nice, did it have a brand or a model number?I went to help a neighbour start his car with my cheap Amazon one the other day.
Not only did it not start it but decided to go bang and turn into many parts strewn across the fields.
It made my neighbour and I jump as bits of it hit the underside of the bonnet!Doesn't sound nice, did it have a brand or a model number?
That happened to my mr2 battery which was left on trickle charge.Not only did it not start it but decided to go bang and turn into many parts strewn across the fields.
Noco kit tends to get pretty good reviews........ But at the price their stuff costs I'd be pretty miffed if I WASN'T getting well made stuff.I bought a Noco 1000a one the other week.
