That's the problem when you make some gates they tend to muliply
and reamed out the farmertec
Rust blue themAfter the success of turning a piece of scrap IKEA steel into something useful, I had another go.
Two spanners for the tapping head that I'm rebuilding.
I think that they need blueing now.
im just asking if you have put support pieces under the horizontal woods as its advisable than just screw some bolts in at either sideRe-arranged the stables feed area.
Previously we had the straw up top and higher up and it was a sod to get up under the eaves end on. We need access to the hay daily but straw probably weekly so that's why it was that way around.
However putting the straw down low we could have a lower mezzanine for the hay bale and also a another mezzanine behind it higher up above head height for more storage.
It's been that way (with far more weight) for four years Gaz and never had any issue.im just asking if you have put support pieces under the horizontal woods as its advisable than just screw some bolts in at either side
Thanks . Use these section rolls.Lovely, what are you using to get flat edge rolled like that?
