Stop trying to "derail" my thread pal. Just as it was building up steam, you had to come and send it off track,and that's just not fare is it. You're clearly getting ideas above your station.Have you posted lookouts? Won’t the fat controller have something to say about this?
I had a friend who wanted to be run over by a steam train. When it happened he was chuffed to bits.
I’ll get my coat.
13mm holes or thereabouts.you havent said what size drill bits . probs need a pilot drill if bigger than 3/8th hss and slow speed with cutting compound
Where? Through the side of the rail. Thanks.Where abouts are you drilling the holes?
If it's new track it probably won't be very hard at all and any decent drill will do.
The top surface might be flame hardened, use a new bit, once through the top layer swap to another bit. Use the first bit again to start any more holes on the top.
If it's used track then depending on use it will have work hardened, most of it should still drill fine. Take a file to the top surface before trying to drill and see how hard it is.
That was done on a fobco star pillar drill with a euruba (screwfix own brand?) holesaw
It did have flood coolant but that was mainly to wash the chips out
Erbauer?
animalsThe permanent way team on LWR just use standard 1-1/8" drill bits (no pilot )for drilling the fish plate holes.
the chissel on the tip of the drill will just scrape through . bet it takes some force without pilotThey use a proper track drilling machine, it's slow but does the job well. Sometimes I think it polishes its way through.animalsthe chissel on the tip of the drill will just scrape through . bet it takes some force without pilot
Split point or web thinnedDepends how the bits are ground. The web is a non-issue on some grinds.
These are a good example:
I figured they would punch them.They use a proper track drilling machine, it's slow but does the job well. Sometimes I think it polishes its way through.
