There doesn't seem to be much force along the length. Most of them use 2 pillow blocks but the heftier ones seem to use a solid tube with a bearing each end.Which way are the loads going, that will determine what type of bearings, and holding arrangement you use. Pillow blocks typically are good at up-down loads but they aren’t designed to take heavy pushing/pulling loads in the axial direction of the shaft. They might be good enough for your application but you might find a better alternative if that’s where the majority of the loading is.
I’ve had one of those (top photo) splitters for years. Much better than up/down hydraulic type due to simplicity, and not having to wait for the return stroke. Tractor can run at nicely low rpm, too.Is the shaft a sliding fit in these?
And what stops the shaft sliding about? Locking collers/spacing collars or something else?
Is it possible to buy the solid tube type like this? If so what do I search for?
Building myself a screw type log splitter.
Sadly not got a tractor. I do have a spare 7.5hp 3 phase lathe motor which should do nicely on a 100mm diameter cone.I’ve had one of those (top photo) splitters for years. Much better than up/down hydraulic type due to simplicity, and not having to wait for the return stroke. Tractor can run at nicely low rpm, too.
Grub screws retain the shaft in the pillow blocks. Make sure the cone is held positively as well, or it’ll come off.
Fit a splitter/riving knife underneath. Stops the log rotating and trapping your hand. You may have to experiment with how far forward to place it.
Make the table big enough to hold partially split logs. Saves bending down all the time. Add a holder for a suitably beefy chopper - I use a bilhook - for chopping away the stringy bits between logs.
Rig up some sort of e-stop (bit of rope to stop lever) in case of disaster!
Funnily enough I did think of just having the auger coming out of the back of the HolbrookPretty easy to turn a bit of tube to accept some bearings in either end then weld it to a bracket for mounting , like said before i dont think in this application there is much axial load once the screw digs in. Im pretty sure you have a lathe or two or three you could it on
I’m not sure what speed I run it at - well under the 540 rpm. Perhaps 100-150. You should have plenty of torque, gearing down from motor speed.Sadly not got a tractor. I do have a spare 7.5hp 3 phase lathe motor which should do nicely on a 100mm diameter cone.
I watched a Youtube video with a bloke using one. Also on the table was a machete! I guessed this might be a problem. They don't seen to split clean like a hydraulic one.
I built a good attachment for my forklift but the 10 ton ram won't touch some of the difficult logs.
Probably not, making it extra "fun".You'll never get enough offset with the tailstock method.
