Hi all,
I’ve got a narrowboat that requires a little work on it.. I’m in the process of replacing the windows. The openings for the windows are currently rectangular, unfortunately the windows I want have a radius corner on the bottom, which means that I’ll need to add a small piece of 5mm steel to ‘fill the gap’. Originally I thought of having this welded but there are a couple of issues with this, firstly the inside of the boat is kitted out and has a ply facia, I can’t remove this without destroying the finish around the windows, so welding would be a fire hazard. Secondly I’m a little worried about distortion of the metal if welded.
Instead, it was suggested that I use an epoxy or panel adhesive. Firstly securing a backing strip of metal to the existing structure (adhered or drilled and tapped) to act as a support, then adhering the small strip of metal over this. In addition to amending the window openings, there is a window I want to remove all together. I wasn’t sure if I could do something similar to above. Create a strip around the window that provided a support for the metal plate to sit.
My question is, does this sound feasible, would there be any disadvantages to welding and what product, if any, would be best?
Hope that makes sense,
Mark
Mark
