This time next year Rodney...I reckon we have a spring
I thought the flux determined what your searching for.I was sceptical about the divining thing but when I had a go I did "find" some water pipes we were looking for .
using welding rods with the flux knocked off and on other occasions , the earth shielding off of armoured cable .
Have a go .
Oh ye of little faith .Your all mad, no scientific test has ever proven divining rods work or detect anything, cause if they did Bosch would make a hand held box that would go bing and they would make a fortune.
dont want to put a decent bet on it do youYour all mad, no scientific test has ever proven divining rods work or detect anything, cause if they did Bosch would make a hand held box that would go bing and they would make a fortune.
Show me exactly what forces are moving the rods and the science behind it and I will give it some thoughtdont want to put a decent bet on it do you![]()
i dont need to scientificaly prove it i can do it . im not a betting man but i will put decent money on it so think hardShow me exactly what forces are moving the rods and the science behind it and I will give it some thought
Yep we're flat hereThe surrounding land looks very flat. Is there a general slight slope down towards the boggy area, and is the boggy area a local low point? Does the concrete apron, that borders the patch of ground, drain towards it? Are there any streams, rivers, or dykes nearby?
a lot of our land is still a bit ridge & furrow the water does lie in the low points, we have dykes all around us which are all very low at present, the point in question is low but we've had no rain for a good week and you can see where it's oozing out where the tops 8 inches has been pulled offAre youon main drains, or septic…its not a soak away area is itYep we're flat herea lot of our land is still a bit ridge & furrow the water does lie in the low points, we have dykes all around us which are all very low at present, the point in question is low but we've had no rain for a good week and you can see where it's oozing out where the tops 8 inches has been pulled off
I don't have to think hard,it's been disproved many times in a controlled environment or it would be taught in college along with how to use a scanner, your happy believing it and I'm happy for you to keep believing it.i dont need to scientificaly prove it i can do it . im not a betting man but i will put decent money on it so think hard
I also don't believe in ghosts, or the lady reading the tea leaves or little green men doing capture and release in the woods
but you wouldnt bet on it
i would so il leave it at that Yes your right, cause there is nothing to bet on it's been disproved, I would like to know what magic force moves the rods thoughbut you wouldnt bet on it
If only you were with me the day I found a blocked drain in the middle of a field, I mean, its not luck, nothing else can explain it, dont let it bother you though if you dont have the gift.Yes your right, cause there is nothing to bet on it's been disproved, I would like to know what magic force moves the rods though
Its a long way from anything, sceptical tank, drains, water pipesAre youon main drains, or septic…its not a soak away area is it
there is meant to be an old bore hole but it's a good 100mtrs away from its supposed position
