dieselsamurai
Too many projects not enough time!
- Hampshire
I think after 40+ years I thought it a good Idea to have a strip down and check how bad my nuts were
on my mill/drill i mean as climb milling has never been on the cards and accuracy was almost within reach
I always planned to sell it when I got my Bridgeport but its always been difficult for me to sell any tool and 1 mill just doesn't seem enough now, Its been really handy for heavy drilling and with the 2 axis dro I'm fitting it will be of more use im sure.
Turns out after a stripdown that the X axis nut was loose hence the large amount of backlash I was hoping that it meant the nut wasnt worn but looks like it made it worse as rocking side to side has ovalised it too
Should be an ACME thread but they are super sharp now
Both nuts are worn X way worse than the Y but unless I can find some like above i need to make some replacements
An evening of light googling and for what seems like a fairly common Milling machine there are no replacements available from what I can see
If anyone knows a source i would be happy to here from them !
If not looks like the thread is Acme form as stated above at 10 tpi the screw is 23.4mm or 0.920" dia so I can make a nut on the lathe
Screw looks ok not as bad as I expected, whats the best material bronze or brass ?
on my mill/drill i mean as climb milling has never been on the cards and accuracy was almost within reachI always planned to sell it when I got my Bridgeport but its always been difficult for me to sell any tool and 1 mill just doesn't seem enough now, Its been really handy for heavy drilling and with the 2 axis dro I'm fitting it will be of more use im sure.
