It’s a Cooper S. 6 speed aren’t as problematic as the non-S 5 speed, and with 69k Im not overly concerned.Oof, you should have bought a gearbox methinks...
No, for the VWIt’s a Cooper S. 6 speed aren’t as problematic as the non-S 5 speed, and with 69k Im not overly concerned.
Ahh, sorry. Thought you weren’t a fan of the BiniNo, for the VW
I lost £1250, not sure if that was clear from my description.Ahh, sorry. Thought you weren’t a fan of the Bini
TBH a box would be £250-300, if the clutch or DMF was in question I’d replace it and then the car is still only worth what it owed me. Car cost me £1500 last Jan and cost me £1500 to get it up to scratch so not a big loss at £1750 after a year.
The PO struck again? Seemed to have been fairly consistent at leaving things loose.Turns out one of the driveshaft bolts had wound it way out and made a bid for freedom then the c shaped bolt washer thing turned on its second bolt then proceeded to cut its way through my gear casing!!! Never seen anything like this before!
Ah, yeah.The PO struck again? Seemed to have been fairly consistent at leaving things loose.
