Mixing metric sizes with TPI is not going to end well I think. 20 tpi is very close to 1.25mm pitch, and 18 tpi is not far from 1.5mm pitch...
Yep think your right m16x2.0There is no M16x20 tpi, do you mean m16 x 2.0? Have you tried a set of pitch gauges?
Male threads typically measure 0.1-0.2mm under size as it makes them easier to die cut, so the 5/8" part could also be M16...
I'm only working on the metric dimension from the valve block suppliers and an Internet search for the Bomford cables bringing up the imperial unf size, not sure what's what nowAn alternative way to state the same thing is that 2.0mm pitch is 12.7 tpi so nowhere near the 18 tpi of 5/8" UNF.
Hence, if the fittings go together, some further investigation is required.
A set of pitch gauges is less than £6 (https://www.amazon.co.uk/Thread-Cutting-Metric-Imperial-Stainless/dp/B0D2TQFT3G).
Every household should have one.
So that would make the metric thread pretty close to the unf then which is why I'm getting a bit of engagement?It seems the threads in the valve block are ISO metric fine. The thread pitch of a 16 mm diameter fixing of this specification is 1.5 mm, which equates to 16.93 tpi.
I reckon so. Good luck with a quick repair.So that would make the metric thread pretty close to the unf then which is why I'm getting a bit of engagement?
I can't get imperial extension for valve block, if I want to change the cables and remote handles to match the valve block it's about £300What is the relative cost of a new valve block extension compared to a new cable?
Whichever is cheaper to replace is the correct part to modify.
M16 x 1.5 is the same as electrical glands so a die to use on the cable might be an alternative to an imperial tap into the valve block extension.
Have you got a lathe and make an adaptor coupling?I can't get imperial extension for valve block, if I want to change the cables and remote handles to match the valve block it's about £300![]()
I have but will still need taps/dies to suit, I was hoping just to run an imperial tap down the extension piece to keep it simpleHave you got a lathe and make an adaptor coupling?
Do you need them quickly?I have but will still need taps/dies to suit, I was hoping just to run an imperial tap down the extension piece to keep it simple![]()
The guys are starting the stock fencing week Monday and I've about 500mtrs of grass/weeds/hedge to flail beforehand so yep you could say its getting tight!Do you need them quickly?
