arther dailey
- England
hi, on face ache see a ad for metal paste on kubrat store , is this one of those scam type listings , has anyone bought safely ? cheers
			it showed a putty thats steel grey , can be put on damaged area and machined/filed . I am looking for similar for tiny repair on a shotgun top rib , needs slight filler then fine filing before re finishing . obviously with recoil it needs to stick very very well.Metaln paste ?
Please enlighten me
Belzona. You’ll crap yourself at the price but it won’t shift!it showed a putty thats steel grey , can be put on damaged area and machined/filed . I am looking for similar for tiny repair on a shotgun top rib , needs slight filler then fine filing before re finishing . obviously with recoil it needs to stick very very well.
If it works, It's worth the price. But I would like to see plenty of independent case reviews before parting with my hard earned.Belzona. You’ll crap yourself at the price but it won’t shift!
I too have out of date Belzona that still works.If it works, It's worth the price. But I would like to see plenty of independent case reviews before parting with my hard earned.
don t knowIs that not "chemical metal" or "chemical steel" aka "plastic padding" hard ?
well woth knowing , both you and othes recomend , but doubt it would be cost effective , only need a pee size piece !I too have out of date Belzona that still works.
Its terrific stuff, In a past life I worked in oil and gas, and at one point we were exporting 150 million dollars worth of crude per day, through pipes with corroded flanges filled with belzona and re machined, pumped by pumps with eroded casings refaced with Belzona and re machined.
Yes its expensive, but your not just paying for the product, but the research and testing that goes into getting it to the market.
Devcon is the other quality plastic metal.
Check the product numbers, there are many, Belzona 1111 is the one Im familiar withSeams there is
I'd be resealing thoes packets after using a bit. Zip top baggies maybe.
Where are you located England is a big place? If you are up this way Ill mix a bit for you.it showed a putty thats steel grey , can be put on damaged area and machined/filed . I am looking for similar for tiny repair on a shotgun top rib , needs slight filler then fine filing before re finishing . obviously with recoil it needs to stick very very well.
