So far into the print as well.
Dropbox
www.dropbox.com
The Worst thing is I don't have a clue either why the print was saying 27 hours when others I have spoken to are getting it to 15 hours standard printing. OR why the print actually failed.![]()
It's petg. Front door is slightly ajar but it's in a cupboard which has its own door.What material? If PLA my lad reckons it could be heat creep.
As in the air temperature in the enclosure got too high and the filament in the feed tube started to soften leading to clogging.
Theoretically possible too with PETG.
I am hoping Bambu as its so expensive has a log file somewhere that might shed some light on it.
I might try salvaging it later. But for now I really want to trace what happened.If you haven't taken it off the bed can you rescue it? Do some measuring, drop your model below the bed the required amount and re-slice maybe?? (Not sure if that would work actually, unless you know of a way to adjust the Z height the right amount).
Or if you have already removed it, what I've done before is to cut the model in two in Fusion and export the top bit to Bambu Studio and print the remainder. Then out with the superglue. I know that works as I often did that with my old Ender 3
Gut feeling is it's not hot in there BUT as its the largest print and longest time I have had it printing it could be.Lad says there's no log file as far as he knows. There is he reckons the whole **hrs recorded on video he thinks.
Current thinking is that being in the cupboard things just got too hot that many hours in.
Not sure where to find the video....lolLad says there's no log file as far as he knows. There is he reckons the whole **hrs recorded on video he thinks.
In Bambu Studio click on the device tab, click on MicroSD card. The printer has to be on. You can download the video to your local drive.Not sure where to find the video....lol
I can't find a full video in the SD card...Lad says there's no log file as far as he knows. There is he reckons the whole **hrs recorded on video he thinks.
It's a time lapse video. Here is a couple that just failed on mine. I still haven't worked out why but third time they are workingI can't find a full video in the SD card...
I can play the time lapse but its the full video I wanted Jake thinks it does record it and I asked in the Bambu group and a guy said pull the SD and check on there. sure enough it has about 30 full length videos on there across the last two models printed. https://www.dropbox.com/s/d1rzr64mxobuid0/ipcam-record.2025-01-30_13-32-13.15.mp4?dl=0It's a time lapse video. Here is a couple that just failed on mine. I still haven't worked out why but third time they are working
The failure starts towards the end of this one.
Seems to be the consensus in the bambu forums. I am just waiting to see if I get a reply on the best settings for this cube pro frame as others are saying it's printing in a lot less time for them.He say:
"best guess is still a partial clog from either heat creep or a bit of dirt stuck in the nozzle/filament"
I thought that would be the case. One thing I really would like to get my head round is why the free files on Maker world can take up to 27 hours on standard setting.You will need to import into bambu studio and slice with all the settings you require, whether those are the standard bambu profiles or if the files you purchased have recommended print settings.
