Is it battery or small genny ( in a van ) plasma cutter proof ??ground anchor made...
and buried.
will float it off later.
just gotta fill the gaps, compact it and make and fit the security post.
it will be for a high security chain through the 'v' and around the suspension arms of whatever i have parked there. they will also be in full view of a camera with voice alerts and link to my phone. i will be making the security post at the front of the drive out of 2" box. i could fill it with concrete, but it would make it heavy and would be pointless because you would only have to cut through the padlock anyway.Is it battery or small genny ( in a van ) plasma cutter proof ??
Fill the posts with oil and denatured water ????
My pal ended up putting lots of tungsten rods in his posts along with denatured water & oil after someone plasma cut his security post off and stole his caravan .
That's brough back some golden memories Ardy .Took time out to build this.
You get the choice of Landing gear up or down.
Put the wall mount screws under the flanges of the hooks unless of course you are going to make domed wood pegs over them as a feature .Took a random bit of old bed frame, probably pine, sanded off the varnish, chamfered the edges and fitted some cast iron coat hooks. Still need to oil the wood, mount it with hidden screws, then refit the hangers over the screw holes.
I'm really pleased with this, i love these cast iron hooks.
View attachment 481354 View attachment 481355 View attachment 481356
Thats exactly what I'm doingPut the wall mount screws under the flanges of the hooks unless of course you are going to make domed wood pegs over them as a feature .
sorry I should have been a bit clearer. ground anchor made...
and buried.
And that's brought back some equally golden memories for me.That's brough back some golden memories Ardy .
My Aunt used to live across the river Witham from Coningsby ( home of the Battle of Britain's memorial flight ) at a little village called Chapel Hill .
One of the runways when flying south sent aircraft to the west of her bungalow . Many a time me & my children and my second wife have stood at the upstairs westerly facing window and waved to the crew of the Lanc as it flew a hundred feet or so away and up after taking off from Coningsby .
T'was an amazing experience , I doubt my kids will ever forget the deep engine roar & exhaust fumes they sensed as it flew by , nor the crew waving back at them .
.There's long been a "rivalry" of sorts between BSAC, British Sub-Aqua Club, and PADI, Professional Association of Diving Instructors.Caravan Utilising Nomadic Traveller
I keep a straight face and tell them I trained with Caledonian Underwater Nautical Training.
.I had two such bits & bobs racks , got them from B&Q over 27 yrs ago the metal frame work on mine is super thin steel poorly jointed. , I ended up taking them apart and soldering each joint Replaced them about 23 yrs ago my lass played merry hell for each plastic click on drawer set was about £18 each two stacks of 8 drawers with to double sized ones at the bottom . The drawers have age hardened on this last set ands several have had then pull lip ripped out leaving nasty sharp edges .Got the "small parts" storage sorted today:
All my nuts, bolts, washers, wood screws, fuses, clips and pins and everything else of that nature is now separated according to type. Still have a few to label but the bulk of it's done and there's enough empty trays to allow for expansion:
Anal? Quite possibly. Easier and more efficient? Most certainly.
So I'm thinking of a final renewal of all my trays ( I'm 74 ) & am looking for a set that will last say ........ 20 years to see me out as ashes
How do you reckon your new drawers will fare???
