BrokenBiker
- Newport, South Wales
So...latest welder arrived today and I had a bit of a prototype to get on with...
Now, due to wrist issues I wasn't a massive fan of the fixed head wp17 on the last welder, but I got by...this welder came with a massive, moulded torch handle with a built in switch that was in entirely the wrong place for me to get comfy so I whipped it off and put my new wp17 flex head on it. Very easy torch to get comfy with, but now I have no switch, so plugged the pedal In and all seemed good.
It became apparent though that even though I spend all day in work using with hands and both feet at once, I can't seem to get it with the welder. I'm either flat out and don't think to ease off so end up traveling way too fast, or I do remember to ease off then forget to ramp up again and end up going incredibly slowly and cooking the part. Thankfully it was only a bit of scrap box section and a few nuts so no real issues.
Anyone got any practice drills I can try so I can get my head around letting my foot work properly? I am fine tapering off at the end of a weld, just not during the weld
Pics below of my first welds using a pedal, I know they are terrible but they seem strong enough for what they need to do (making compressed wood bricks from the shavings off my father's lathe)
100 amps max, 2.5 blue tungsten, 1.6 filler, no 5 cup and some vague attempt at using a foot controller.
First weld with this machine, strangely I struggled with tacks on the other machine, easiest thing in the world with this one. Bodged the start and the middle but overall, better than I expected
Slightly better on this side
Welded a nut to a plate that will slide inside, and damn that's ugly
Then stuck a nut on some all thread to make the bolt that's going to pull the plate, no filler on this one just left the thread a tiny bit proud. (And yes, I know both nuts should have been cleaned but I had time against me)
Final item minus clean up and a splash of paint
Plates don't touch all sides of the box as there will be water squeezed out when in use
I'm happy with the strength of it, that's about as far as this one goes...starting to wish I'd used stick
