OscarInline
New Member
- Riga
Hello. I Started working on a DIY project making a rotary draw tube bender needed for my upcoming projects. This is my first experience with bending tubes, so wanted to consult about a couple of questions.
Right now working on a 100mm radius die to bend 40mm outer diameter 2mm wall thickness tube. Bends needed to be made will not exceed 90degrees, so I'm making a 100degree die (to be able to over bend a little to take springback in consideration)
So my main question is how do you think in this case could I attach a simple lever straight to the die to make these bends (space a round the bender in garage would allow me to use at least a meter long lever arm) or the force needed to bend this kind of tube would be way too much to force these bends and I would definitely need to make this bender with this kind of ratcheting and pin reseting lever arm like most of these rotary draw benders are made.
Would save a lot of time and drilling holes in thick plate to make the lever arm simply attached to the die.
Any input will be greatly appreciated. Thank You.
