Johnnybravo
- Northiam
Will only probably get back on it two weekends time. Inundated with workWhat are your voltage readings on the input pins?
I do suspect you’re making this more complicated than it needs to be. If you need to get some voltage down to 5V then a generic 7805 is a very easy way to do this.Having looked into this a bit further , I am not convinced this would be a straight swap with a normal 7805 in that if you Google that part number it seems to be bipolar and able to regulate both positive and negative 5v
Bipolar is simply the technology used to make the regulator. As a 3 pin device it can only regulate one polarity.Having looked into this a bit further , I am not convinced this would be a straight swap with a normal 7805 in that if you Google that part number it seems to be bipolar and able to regulate both positive and negative 5v
It does seem a strange choice of component for the purpose,
Your comments tie in with what the technician said to me. Each voltage regulator has two capacitors close by. He suggested replacing both voltage regulators and all four capacitors. Probably for exactly the reason you mentionedBipolar is simply the technology used to make the regulator. As a 3 pin device it can only regulate one polarity.
LM7805 or uA7805 from TI should be a suitable replacement - having 7.5V input doesn't require a low dropout regulator (but it is close to the limit). LM2973 from TI might be a suitable replacement depending on the input and output capacitor values. It may be easier to find this part and change the capacitors if necessary.
You should check if there are capacitors close to the device on the input and output, if these are missing or faulty any replacement is likely to fail after a time. The low dropout regulators are less tolerant of this so I suspect may be the reason for failure (oscillation leading to overheating).
There must be a reason they chose to use the components they did. The Japanese are not stupid, and this machine was built to do a job. Not built to a price ! The very reason why they went bankruptI do suspect you’re making this more complicated than it needs to be. If you need to get some voltage down to 5V then a generic 7805 is a very easy way to do this.
As per my and other queries, what’s the readings at the pins?
Like I have said already, inundated with work so won’t be going back into this for two weekends. Want to have the necessary components to hand by then.
The next upgrade to that machine that distribution board was changed and powered by its own separate power supply that was piggybacked into the back of the main power supply’s heat sink.Not normally except for Sony's suicide missions, but that choice of component is peculiar, almost as if they found a problem and scratched around for a solution. TO-220 is not normally vertical either, the hole is for fastening it down.
Pretty common to stand TO-220 devices up like that. Once you get it sorted if you can hold your finger on the tab it is passable.
