OK, let me try again. I used this setup, with the v-blocks where the bearings would be, and rotated the spindle.
(I've actually inverted the photo so it's the same orientation as the original readings.)
The readings are underlined in blue here (below the original readings). The two figures to the right are the ID and OD of the internal MT.
Is it safe to say that the spindle is bent at the splined / pulley end? And would that bend at the top of the spindle, above the bearings, account for runout at the bottom of the spindle, below the bearings?
If so, what is the best way to set about straightening it? We have a hydraulic press, but what would the setup look like?
Thanks.
Thanks.
straitened it back up with a copper hammer and a clock gauge
all good now
