Thrashsmith
Hi all, I have an old column & base from a floor standing Elliot Progress drill which died a while back. The column is 69mm diameter. On the column there's the table, which I was thinking of bolting a bench vice to for the sake of locking work pieces in that I want to drill with a mag drill.
I'd like to fabricate some kind of split collar system with a piece of plate welded to it that I can sit my mag drill on, so I can drill the work pieces on the table below.
The collar will have to grip the column like s.. to a blanket, so there's no chance of it slipping, if the mag drill bit snags.
What do you think is the best way of fabricating the collar? Should I forge the collar from something like 60x20mm flat? Or should I buy pre-made collars? Does anyone know where I can buy especially wide shaft collars?
I guess the collar should have some threaded holes in the sides too, to allow bolts to go through & bite onto the column, for extra grip?
Cheers
Cheers
