daleyd
- Wrexham, North Wales
Like it’s shown on the picture on the box!Would it not work if the left hand side of the belt went around the tensioner and the right hand side straight?
My thought as well.Would it not work if the left hand side of the belt went around the tensioner and the right hand side straight?
Rollocks.Like it’s shown on the picture on the box!![]()
It looks better, but now it is to tight for the small elec motor to turn it over,My thoughts exactly.
Schoolboy error there tya...Rollocks.
That is another mistake in the manual.
Lets have a coffee and rebuild it.
Have you put oil in it?It looks better, but now it is to tight for the small elec motor to turn it over,
The manual states to use Veg oil for the moving parts, so yes.Have you put oil in it?![]()
Better check the valves as well!Rollocks.
What? You read the manual?? I don’t believe itRollocks.
New Ford wet belt lash up?The timing belt assembly was very poor. The designe allows the belt to slip or not rotate
You've bent the valves, better set fire to it...It looks better, but now it is to tight for the small elec motor to turn it over,
That was weighed in as clean ally.Was your goal to convert as much good quality recyclable aluminium into alumina scrap?![]()
