OJCar
- Lothian & Westmorland
*Not sure this is the right part of the forum for this thread - Mods feel free to move*
I need to drill blind holes 6mm diameter 5mm deep in the end of SRBP rod 13mm in diameter.
Ideally the blind hole should be flat bottomed rather than the cone shape a drill bit will make.
I do not have access to a lathe, just a pillar drill.
The parts are guide buttons that go on the end of a modified 5/16 UNF bolt
as a part of a Classic Car braking system.
The original guide buttons made by Girling have not been available for many years.
What sort of speed should the drill be running at ?
Are there flat ended cutters that would be better to use than a drill bit ?
Cut dry or what lubricant ?
Some NOS
Some NOS
you can buy them
