I agree!That detail will be lost on most laser cutters, its just too thick. That narrow slot in particular will turn out wierd. Rule of thumb is holes should never be less than 0.5x material thickness - ideally 1x.
You'd get away with that shape in 5mm in N2 cutting, but 10mm O2 cutting no way.
Yeah waterjet might be a good option. Wire eroder would be even better for accuracy... Obviously cost goes way up thoughI agree!
Water Jet cutting could be an option???
Andy
I would have thought laser cutting was accurate enough for the job being it's the bees knees of cnc cutting, guess I'll have to hope my 3d printed test piece is good enough to simulate a metal version!
You can 3D print in stainless now. That might be a possibility.I would have thought laser cutting was accurate enough for the job being it's the bees knees of cnc cutting, guess I'll have to hope my 3d printed test piece is good enough to simulate a metal version!
Is a Harry Homeshop doing it ?You can 3D print in stainless now. That might be a possibility.
Aside from the kit to actually print it, metal powders are a rather niche industrial product and extremely expensive.Is a Harry Homeshop doing it ?
The lab I visited that was doing it was very expensive.
I agree, its horribly expensive and you'd only do it for components that are otherwise impossible to manufacture.Is a Harry Homeshop doing it ?
Yea jlc3dp is £6 for a piece in 316 and there's a new user coupon of £5 off, I'll just add it onto my upcoming cnc quoteYou can 3D print in stainless now. That might be a possibility.
Nitrogen blanket on the one I saw, space man suits in handling the powders.Aside from the kit to actually print it, metal powders are a rather niche industrial product and extremely expensive.
If you wanted to do it at home you might want to invest in large ball mill to make the powder yourself!
Im unsure if SLS also requires an inert argon atmosphere, quite likely for some powders that would otherwise be explosive in an air atmosphere.
I haven't looked deeply into it but I seem to remember that Driving4answers on utube had a small rocket engine printed in SS for a surprisingly low cost. The parts looked beautifully finished.Is a Harry Homeshop doing it ?
There's the rub right there.....I haven't looked deeply into it but I seem to remember that Driving4answers on utube had a small rocket engine printed in SS for a surprisingly low cost. The parts looked beautifully finished.
