Today was a good day - I finally made a 35mm punch and die set that cut's 6 perfectly circular 3mm holes nicely (In one go).
Excited by this, I thought I'd probably better try and harden the die (The punch pins are already hardened) before use in case I wear it out, and the holes get sloppy, leaving tags on the rear side.
I sorted out a bath of engine oil ready for the quenching, and off I went. Heated it up to glowing red hot, and dropped it gently into the engine oil. Half an hour later - some nice warm oil, and a blackened die.
It was then that very excited me tried the file test - fully expecting (OK Hoping beyond hope) the file would skid happily away from the surface, without even leaving a mark....
No such luck. The file left some very nice file marks - evidenced by the bright silver over the darkened colour that remained after the oil bath.
It was then I remembered I'd practiced making this die so many time, I'd used all my 'good tool like steel' and used mild steel.
Is there anything I can sensibly do to make this any better/harder? Assuming there isn't, and I just need to remake it AGAIN (It should be much easier the 5th time
) but out of higher carbon steel, does anyone have any additional pointers on hardening that Youtube doesn't? Also - as it's a die, and unliely to suffer impact - do I need to temper it?
