Hi all
I have a set of forward controls I am trying to remove from my motorbike, part of which necessitates the need to weld a nut onto a section of threaded rod in order to be able to turn the threaded rod and remove it from the recess it currently passes through. I have tried mig welding (with my blue coloured Clarke Weld Turbo 130TE mig welder with bottle of Co2/ Argon gas - pic attached of seeting available) but when I let the nut cool after welding it on and then turn it with a spanner theres a little resistance but then it just rips away from the top of the threaded rod. The weld does not seeem to be penetrating the threaded rod, I have taken some pics of the nuts that I have welded and broken away - these are just plain steel - no coatinmg at all.
Can I ask for your advice as hoping from the attached pics you can poi nt me in the right direction to resolving the issue.
I am not a welder so hence the question and request for some help.
Thanks
Mark
Thanks
Mark
