I find it's much more satisfying to print stuff you've designed yourself, especially if it's functional bits for the workshop.Chuffed to bits.
Is it possible to reduce the length of an object in one direction using bambu studio.
@Onoff lads showed me how to do it uniform or non uniform but I need the width increasing at a bigger % than ghe length.
I reduced the length by 5mm on the object but it played havoc with the threads (they go tight)
I need to take 5mm of the one end not both.
Ok mate. Will be back on PC soon.Email me the file and I'll get my lad to do it and video it.
This is the original of the file I am working with...Post the .step and the modifications that you need.
The keyway / slot is just to tighten it after you fill it with dead batteries or sand etc.Is the keyway in the cap significant? I'm assuming that is where the spool gets mounted. The thread in the caps is M60x5.5 with the threads reduced by.15 for clearance, so it needs a cap generating with that slot, or more sensibly a fixed cap at the ends. I may have run out of time for today.
