TimGC
New Member
- Dorset UK
Hi,
I have a Wolf Dakota 2hp 100lt 10 (wishful) CFM machine obtained from Amazon I believe, back in 2017 at the latest. I'm sure it's just a far east made unit painted and marked up for whichever big box company that batch was made for.
It has only had around 2 hours use and then was stripped down for conversion to a vertical receiver with the pump and motor connected elsewhere.
The receiver is in a 'bare bones' state as my son stripped it down. Unfortunately, while at university, he chose to remove himself from the gene pool. When we sent his Range Rover Classic to someone who was more than happy to continue the build, it is possible the box of fittings for the compressor went with it. Now, after an extended period of time I have decided to complete his idea.
Here are my questions: Could someone please supply me with the correct thread sizes for the pipework needed to join the two entities' the large tube from the cylinder head to the non-return valve unit then to the receiver and the thinner pipe from the Valve to the control assembly.
I will get the pipes/ hoses made up in line with his plans as I don't have the originals, besides I think they would be too short and inflexible.
I have read here about building a water trap using Dessicant. I'm familiar with that idea as I have something similar in my shower extractor system (Bad planning as I couldn't get the hose to the eves. I just dry it out every couple of weeks. So, I will incorporate that system.
The Machine will be used mainly for resin casting, wood turning, and general-purpose air in the shed.
Thank you
Tim
Thank you
Tim
) & wishing you all a happy and a successful '25.
