Have been using them for metal 3D printing as well as some basic machined parts. What came back was very impressive, especially for the price![]()
Online CNC Machining Service - JLCCNC
Get precision CNC machined parts online! Fast turnaround (3-5 days), custom milling &acrylic services. Upload your design for an instant quote &real-time tracking.jlccnc.com
These were advertised a bit on some YT channels I watch, they also 3d print SLS in stainless.
What does the model look like ?Need a couple of parts cnc'd for prototype testing to destruction so not needing aerospace precision as ideally want to keep the cost of the parts low and after nearly having a heart attack with xometry prices though I'd ask here.
Thought they were pretty much America only since international shipping, wish we had something like them and mcmaster-carr here![]()
And below is without vatWhat does the model look like ?
Post up a screen shot and the price from xometry.
I use them for my PCB prototypes. Turn round is usually 1 week from uploading the gerber files to receiving the boards. Postage is around £16 for 2kgs. It does step up a bit when the weight goes up!JLC are based in China, shipping is supposed to be quite fast.
I'd machine them for that price!
I can send you the files if you'd like to have a lookI'd machine them for that price!
From those thumbnails, there doesn't appear to be anything too complex to them, unless you have machined features on the underside?
The wheel could be the most problematic, depending on what the shape/profile is around the OD?
The biggest cost is the setup time.
If you're not in a rush, I'll probably have some time over Christmas/New Year, although I doubt I'd have material for the Body.
I think I've got some 12mm bar kicking around, but I'd have to check (certainly got 8 and 10mm). I might have some 20mm bar buried somewhere, but I've not machined anything that thick for a while, so can't remember what offcuts are lying around.
I can send you the files if you'd like to have a look, I'd buy the material for it if I could find a seller for 7075 as seems like hens teeth on ebay lolI'd machine them for that price!
This seller has L168 which is a high strength alloy if that's any good?I can send you the files if you'd like to have a look
Just spotted this - https://www.ebay.co.uk/itm/226072196891This seller has L168 which is a high strength alloy if that's any good?
https://www.ebay.co.uk/itm/185866911271
May be worth asking @hotponyshoesJust spotted this - https://www.ebay.co.uk/itm/226072196891
Could definitely work as fits all parts but hefty bandsaw required View attachment 476788
Decided to have a look again after seeing the high prices first time, didn't realise you can select the time frame to drop the cost and cheaper shipping options and new user discount so can get all 4 parts in 7075 anodised and shipping for the price of 1 part other companies were quoting at £150 all in![]()
I've just put 2 and 2 together and realised it's same seller as usernameMay be worth asking @hotponyshoes![]()
The main aluminium parts have overall dimensions of -I can probably slab it up with the bandsaw if required although I've got plenty of other sizes in 7075 that may do the job.
What sizes do you actually need?
132*82*18mm
64*54*12mm
51*51*10mm
130*82*3mm
And I need 2 of my devices since one will be tested to destruction and other probably the same fate just after other not super destructive tests hence checking all could fit in the block before realising it's your ebay lol
Ultimately it depends on if I can find someone to do the cnc work for a reasonable price but would be pretty hard to beat the jlccnc quote at £150 shipped AND anodised (anodising isn't needed for these test ones as shouldn't chance the material properties that much but at only a couple of quid extra might as well) as most western companies can't compete against Chinese mass production unfortunately :/
