Right I'm back , just had a look at the inverter and there's a blanking plate where the dongle thing goes I reckonView attachment 475868View attachment 475867
Get a 4G router and take it with you to the garage. We binned Openreach just recently and got a 4G router, we’ve doubled our speed and halved our monthly bill
Yeh, mine has a swivel round plate with the socket for the dongle.
If you want the internet for radio, browsing, YouTube, whatever rather than being just able to access your solar inverter you might think about an access point. I use three Ubiquiti UAP-AC to cover my entire plot of 4 hectare. TP-Link do a poorer but cheaper version and there are no-name generic Chinese ones which have mixed reviews. They work on power over LAN so are powered by the LAN cable from your router. If you have a big yard they are well handy in the summer if you use your garden or loaf outside. If your garage is not made of Mu-Metal or out of binocular range of your house then an access point mounted on an outside wall of your house facing the direction of your garage will do the job.
For sure you know it's the easiest method to get internet to the OP's garage without faff. Plug the LAN cable in both ends, connect to and then give it a name and Wi-Fi password, done. I see tips to use 4G/5G routers, its like a different planet, there's no 1G coverage within 4km of me.I use Tenda units. Not had a problem with those, & considering they have thick stone walls to contend with, I get reception outside a good distance from the flat.
Following on from this, is there not a risk if either the earths are different between garage and house or there becomes an earthing problem at the garage?
TBH I'd try to get wifi running first (as has been suggested by a couple of others).
Ethernet data lines are transformer isolated at either end, so earth loops shouldn't be an issue. However, ethernet cable screens would provide a continuous connecton end to end, provided the Ethernet jacks are designed for screened cable. The Ethernet connections shown in the image of the back of the router (posting #4 above) are clearly insulated, so earth potential differences wouldn't be a problem.
So without distracting from the OPs question whats the difference in idiot terms between a router and a switch?
Yep, the same. we hardly used the landline. Only really had it for internet.I've been running on 4G initially, 5G now, since I moved into this flat. Saw no point in paying line rental etc. The setup suits me fine.
I'm assuming I'll get a better range if the TP link aerial is in the line of sight ? I mean for range , it's got a good signal in the garage where the inverter is but thinking for in my field which is higher than were I've mounted it . So if i.put it up on a pole , might just tape it too a long piece of wood to see if the range alters much
