arther dailey
- England
rsj , clad with composite so no rot.
Naw, just paint the steel, and then use a feather to make some fake grain....For all you "steel posters", how about just timber cladding one of the acrows.![]()
Looks like you could graft a lump on the bottom and then bolt some steel plates on the sides of what's there already there maybe?Cut off six or twelve inches, graft in a new bit with wedges ?
Just looked up the price of 100mm by 5mm box section, would be more than £100 delivered.
I've had this "Roundtuit" thought of a "Car Port" type thing as a covered working area in between my block-built workshed & the house (lack of space inside the shed & to take dust/debris out of shed).Just looked up the price of 100mm by 5mm box section, would be more than £100 delivered.
the original was 200 x 130 one post 4 x 4 probably to small or did you mean 2 bolted screwed side by sideI've had this "Roundtuit" thought of a "Car Port" type thing as a covered working area in between my block-built workshed & the house (lack of space inside the shed & to take dust/debris out of shed).
My first thought was box steel uprights.
However it's around £100 a post in steel versus more like £15 for a tanalised timber 4" × 4" post.
At that cost difference...
The OP could get a square fence post tanalised to do his job cheapest. Stand the ends in creosote for a day, & it'll see any of us lot out.
Whatever works tbhthe original was 200 x 130 one post 4 x 4 probably to small or did you mean 2 bolted screwed side by side
Just watched that vid, excellent. I would so easily make a right a$$e of it.if you want wood double scissor joint
if you noticed his post is split and has been made out of a few piecesJust watched that vid, excellent. I would so easily make a right a$$e of it.
