My Old Landy
Engineering Mayhem
- North Lincs
Pneumatic die grinder or electric? Turn the pressure down on the airline regulator if it's pneumaticmy die grinder isn't variable speed, and without a shield I'm a bit nervous.
Electric, though I do have an air one. I haven't used it for ages, not since I bought the electric one, I'd almost forgotten it was there. I'll have a go with it.Pneumatic die grinder or electric? Turn the pressure down on the airline regulator if it's pneumatic
Finished chain.I have been convinced to try a Stihl PM3 chain in the Echo 2511 chainsaw, supposed to be the best but at 5x the cost of others. However inna climbing saw it will last well, whatever I use. They are not available in the correct 60DL so had to buy a 64DL and shorten.
Had a look at this today. Generally 1/4" master links are not available and on my other chains I generally can reuse them.
Stihl are a bit stingy on the rivets - tho the look pretty! there is not enough meat to sensibly reuse them combined with slightly smaller drive link/pin holes that wont fit other brand links. A pain.
The quick option which I prefer will be a nice blob of 1.6mm stick weld on the pins, which I have had success with before. It is not always pretty I could TIG but Im out of gas.
The other option is to turn some new pins on the lathe from en16t steel and rivit both sides, but my tiny shed, I have no space to put everything and it would take an age to get access to lathe.
Stick welding it is!
3 Hours work, but the convenience of the kit is a given and the arbour, pad and other bits are good for the job, enough left in that kit to do another 2 pairs.For her and other drivers!
It would be interesting to know how well the UV protection fluid has worked in a years time. I polished my Mazda 6 lights before summer, they were great, sadly they have already started to cloud over. Next time I will spray them with 2k clear.
It's ok man, we know them for you..... for some guys on the Africa Twin forum.
Not at this point in time, I have panniers that clip on rather than bolt on so unless I can design these to do the same I probably won'tIt's ok man, we know them for you.![]()
No, wouldn't really be room for an effective cross brace as it would have to be curved up that high for wheel clearance that it would be ineffective.@Hood are you going to put a cross tube between them so they don't bend in?
