Hiya,
Need to do a bit of patching for an MOT so pulled the old SIP HandyMIG out. Doing a few trial runs on scrap everything was working OK (for a SIP) and then it started spitting everywhere before refusing to feed. (I hate this welder - so many problems!).
Anyway, the issue seems to be that the knurled adjuster on the spool holder (that stops the spool from bird nesting) is tightening up as the welder is feeding resulting in the spool becoming difficult to turn.
Has anyone come across this issue and how did you resolve it? Options I've thought of are :-
A) Chuck a set of mole grips on the knurled adjuster to stop it from turning.
B) Use a thread locking compound on the threads of the adjuster.
C) Drill a hole through the knurled adjuster and use lock wire.
What is the recommended solution to this issue? :-(
