RIP
Kairo
- Netherlands
This is a method I've found works for making custom brackets for my buggy build. It's absolutely not for everyone, but I'm faster with CAD and CNC than I am with an angle grinder. It also avoids late night noise that would otherwise annoy my neighbours. In this example, I needed a custom alternator bracket with 1mm accuracy to get proper belt alignment.
The method starts with first making a bracket out of plywood using a low cost 40 watt laser cutter. It takes several goes to get a precise bracket, adjusting the design after each attempt. I use superglue for the plywood because it dries almost immediately and is strong enough to support a 6kg alternator in this example. Once I have a plywood bracket that fits and works properly, I send the final drawings off for cheap eBay laser cutting.
I've made some pretty neat and elaborate brackets, and as always, forgot to photograph them until this last simple bracket.
thought i would mention that bit.
