dieselsamurai
Too many projects not enough time!
- Hampshire
Hand pump on my 25ton press always leaked a bit but much worse now i always planned to replace with a air over hydraulic but funds are tight right now
does anyone know where i can get seals like those below ?
there are 3 rubber washers under the top cap from the left then a threaded pin spanner nut with what i can only describe at 4 washers stacked that are shaped like a hollow doughnut cut in half
is this a standard setup ? I have 3 others but they are set up for other hydraulic things they have never leaked so never needed to strip them down
this it the offending item i dont think it is an Enerpac may be a cheapy one
If the seals are stupid money i'll look out for a second hand one but they look like they should only be a few quid but i bet they wont be...
the piston doesnt look to bad if it is a clarke then maybe i can get spares . Ive got a few other pumps with quick releases but they are all different types i'll have to have a rummage around to see if i have a spare female one of the other type as the on the 25tom ram in my press was yet another different type sods law
