I feel there's a limerick in there somewhere.Agreed, when I last had an O licence I was running a couple of 7.5t Mitsubishi Canter 2 car transporters, even with the twin decks we could carry 3 tons, though that was only a couple of Ford Focus’s.
Edit: And that was a legal 3t - full tank of fuel, winch, traffic cones and a crew of two fat Brummies!
No. They just need a suitable annual test.Sorry to slightly off topic the thread.
Is the 6wk inspection a requirement for a large(over 3.5 ton) domestic vehicle like a massive camper van/mobile home?
Stu
Yep, my 3.5t Master Camper Conv is tested to C4 (passed about a fortnight ago). Where I took it couldn't have tested the same vehicle if unconverted as they don't do C7 (but old-school place with a pit not a ramp, so bigger stuff not an issue).No. They just need a suitable annual test.
Registered motorhomes can even be tested by any class 4 (IIRC, although might be class 7) test station, provided they have suitable equipment to handle the vehicle aka as long as it fits on the ramp, and the ramp/jacks can lift it for inspection, it can be tested. However anything larger than 5t will likely have to be done at a DVSA test lane due to the size.
There's a bloke in Southampton knocks them out on Facebuke Marketplace, isn't there?would a hiab trailer be better?
Yeah this is what I was kinda getting at. The cranes and Jack legs themselves are very heavy (for any sort of decent tonnage) AND they need a decent weight of chassis to work safely.The issue with a crane on a 7.5t, is you might be limited by what the crane companies will recommend to be fitted to a 7.5t due to the the required chassis/ballast weight.
When I done an Atlas course, the instructor had had to investigate an accident that involved a lorry on it's side with one of their cranes fitted.
It turned out Atlas had refused to fit the size/configuration of crane to the chassis, as they had deemed that the chassis wasn't heavy enough to provide the required ballast weight, so the customer had just bought the crane and fitted it himself. IIRC the insurance company weren't too impressed.
It's why one of my previous employers had cranes fitted to seemingly oddball 13t chassis.
It was the smallest chassis Atlas and Hiab recommended for the size of crane they needed, as they wanted the smallest chassis possible for best manoeuvrability.
Any other customer would likely have opted for a far more common 18t chassis, but that would mean bigger wheels and a longer wheelbase.
Wait until you see the parts prices for hgvs these days!
Also seems the ministry are dead keen on anything slightly unusual.
I think voluntary headlamp test is 20 quid and voluntary brake test is 80 quid, then add in the actual test cost itself.Yeah it not a cheap exercise getting a 7.5 tonner booked in for a test/retest and buying a few parts to get it thru.
Makes you wonder if you are gonna do it - get a lorry - jump thru the hoops - you might as well - get a two axle 18 ton rigid.
Do them two things the day before the actual test and the rest if half tidy will pass with no issues, brakes can be the biggest unknown hence the voluntary tests.
So if you haven't got brake rollers you cannot do inspections?Next year they are insisting on a laden brake tests at every pmi, in theory other than a wash down any truck on the road should be able to pass an MOT at any given time.
Bob
I suppose you could if you have an arrangement with an outfit that has them. PMI's are about to get expensive so I am thinking of installing brake rollers, a pit, pit jacks, beam set and doing our own PMI's.So if you haven't got brake rollers you cannot do inspections?
I used to look after 7 trucks on the farm my brake test was run them across the yard and check all wheels locked. But that was nearly 30 years ago. I certainly don't miss it, all on drum brakes and leaf springs incredibly hard work.I suppose you could if you have an arrangement with an outfit that has them. PMI's are about to get expensive so I am thinking of installing brake rollers, a pit, pit jacks, beam set and doing our own PMI's.
Bob
Pit jack massive time saver, wish I had a pit jack, and not a steel beam and bottle jack!I suppose you could if you have an arrangement with an outfit that has them. PMI's are about to get expensive so I am thinking of installing brake rollers, a pit, pit jacks, beam set and doing our own PMI's.
Bob
I had a man 7.5 t with ally body and crane . It weighed 4750kg unladen.View attachment 473086View attachment 473087
this old thing had 3.8t payload. with a steel body. with a ally body id expect itd have 4t avaliable even with a crane.
Bob
