dont over think it just a bit of common sense and care needed .8x6 shed Virtually empty as it is but I could empty it completely. It’s built on a solid concrete base so if need be I could remove the wooden floor and just leave sides and roof.
You will be fine. Just leave the door ajar abit to let some fresh air in.8x6 shed Virtually empty
the wooden floor could be an issue but with protection and weld 2hrs before you should be fine8x6 shed Virtually empty as it is but I could empty it completely. It’s built on a solid concrete base so if need be I could remove the wooden floor and just leave sides and roof.
Good on the floor, consider adding drywall (gypsum board) to the walls.8x6 shed Virtually empty as it is but I could empty it completely. It’s built on a solid concrete base so if need be I could remove the wooden floor and just leave sides and roof.
