I hope someone can help.
I just bought the 150TE to construct a frame so I can build a cover my vehicle trailer. I bought 16g 19mmx19mm steel box section also.
I've been practising with off-cuts before I embark on the real job. It seems that the lowest setting (MIN and 1) works best, although moving it to MAX works also. I have a wire speed of 6, gas 3 and the wire is 0.6 mm. Do these settings make sense?
I am a bit worried that I have I bought too powerful a set. If I am bit heavy handed I blow holes in the 16g especially towards the ends of sections. Will I be able to weld thinner section than 16g in the future? Is this just down to my lack of skill?
(I have been told that getting accurately gauged steel is impossible these days - borne out by the stuff I bought from a reputable supplier, it seems to be 1.2mm thick).
Last question, I deliberately avoided getting the 151TE because it seemed to need a higher rated power supply. With the 150TE I just wired up a 13amp plug and plugged into my garage ring main and got stuck in. Now I read in the manual (yes, yes, I know) that I do need a higher rate for the 150TE also. My 13amp plug is not getting warm and the mcb is not tripping. Nevertheless should I sort this out? If so what do I need to do? Garage has a separate consumer unit so I could easily set up a separate circuit for the set.
Any help most welcome.
