I am in the process of planning a tipping garden trailer and using a flowfit kit with a 12v hydraulic pump and ram to make the trailer tip. I would also like to build a log splitter. So my thought process is, is it possible to get a flowfit double acting 12v pump with two sprinter sized batteries powering it on the trailer and have to option of having it tip the trailer or use it on the log splitter. Do you think this would work?
I understand the pump may not have enough capacity to run a log splitting ram but worth an ask?
Ram:
www.flowfitonline.com
Pump:
Ram:
Hydraulic D/Acting Log Splitter Cylinder, 70 Bore, 50 Rod, 550 Stroke, 767 Closed
Hydraulic Double Acting Log Splitter Cylinder 70 Bore, 50 Rod, 550 Stroke, 767 Closed, Unpainted Body, Maximum working pressure: 200 bar
Pump:
12V DC Double Acting Hydraulic Power pack 4.5L Tank 1.6KW | Flowfit
View Flowfit's Flowfit 12V DC Double Acting Hydraulic Power pack with 4.5L Tank ZZ004232, Max pressure 200 Bar. Call 01584 876033 Now."
