Wichwoman often works from home, if we pop out in the camper how's best to charge her Mac / Laptop?
Don't fancy an inverter as too much wastage and drain on the battery. Can you get a 12v Mac book charger?
A dc-dc boost converter will be far more efficient than a 240v mains inverter. You would buy one to match the required output voltage and current.If the Mac battery is over 12V then there is no way other than an inverter. If it is a 12V input, then just a cable should do.
Years ago I bought something branded "Juice" - cigarette lighter adapter straight into their box of tricks & then out to the laptop with one of the brand specific adapters. I've made I sound a lot more complicated that it really was & worked a treat.Wichwoman often works from home, if we pop out in the camper how's best to charge her Mac / Laptop?
No an inverter's output (in this context) is AC.It is still an 'inverter' regardless of the input voltage.
I disagree but with regards to efficiency from a battery source, mains equipment is usually terrible, which for me would rule out a 240v inverter.It is still an 'inverter' regardless of the input voltage.
Problem is I only have 100ah of battery power so not really enough to run itBite the bullet and fit something like this:
Victron Energy Phoenix Pure Sine Wave Inverter - 12V 375VA (VE.Direct-enabled)
Victron Energy 12V 375VA professional, high efficiency, pure sine wave inverter with VE.Direct interface. For caravans, motorhomes, campervans, boats.www.12voltplanet.co.uk
Very low standby power (zero when switched off), pure sine wave and plays well with all sorts of mains adapters.
90% odd efficient.
Chalk and Cheese vs the Chinese inverters on Amazon/Ebay/etc.
Have had one in our camper for the last couple of years and it just works.
That's the same problem whether you use the inverter or some sort of 12V supply direct - most of of the power used from the battery will be what the laptop needs, however it gets there.Problem is I only have 100ah of battery power so not really enough to run it
A 20,000mAh (or 20Ah) power bank takes something approaching 100Wh from a 5V USB supply to charge it. Factoring in the inefficiency of the charger, that's probably about 110Wh drawn from the supply be it from 12V or mains. That's a pretty large chunk of a car battery's available charge.
The MacBook Pro battery is quoted as 58.2Wh, so around 65-70Wh drawn from the external supply.
