Islander71
- West Scotland
I have an early Iskra 5Kw wind turbine now about 17 years old. The company was taken over at least twice, and the present company currently appear to have no information or parts for these machines, and all the people who designed it have long retired.. The blades are speed controlled by the blades twisting (rotating ) to spill wind. The spring loading can be adjusted to give the designed rotor speed, which before the invertors kick in loading the generator should give a voltage of 410-470v with the blades feathering. This all works fine with it currently feathering out at 430v. There is an complicated electronic brake control device which shorts the 3-phase generator output into braking coils should it overspeed. This can also be triggered by a switch with 2 x 9v batteries at the base of the 12m tower to manually stop it. The original brake control unit failed at 11 years and a special one-off brake unit was built for it by the original Iskra electronics engineer. It also stores the data as to why the brake operated which can be de-cyphered by a series of sound beeps.
This unit from the start was overly sensitive to sudden gusts of wind shutting it down in gusty but not high wind conditions. I got steadily worse until I replaced the 2 "impulse relay units" with the 2 from the old brake unit, which enabled it to run with de-tensioning the pitching springs to give a reduced output of 3.7Kw. With this it only occasionally shut down for no good reason. At its recent service I increased it to the rated speed so it now gives a max of 4.7Kw, but the brake is coming on frequently at fairly steady wind speeds below its full speed - the turbine is running steadily at maybe about 4 Kw when it will just suddenly brake.
These are the 2 impulse relays - Finders 20.22.9.012 - https://www.digikey.co.uk/en/products/detail/finder-relays-inc/20-22-9-012-0000/10055779?utm_adgroup=&utm_source=google&utm_medium=cpc&utm_campaign=Dynamic Search_EN_Product&
I have no knowledge of electronics, but wonder if I could replace the 2 relays with less sensitive ones, does this sound feasible? If so could anyone suggest suitable relays. Or is there anything else I could do?
The The only other option I can see is to disconnect the brake coils and hope it doesn't overspeed and destroy itself!
f.
f.
