Tupers
Now that's an interesting mod. Do you think the motor will be too annoying in the cabin? On the other hand, it'll be the cleanest mini engine bay I've ever seen.
I think it should be OK although I'm planning on wrapping the motor in sound deadening just to knock a bit of the noise off. Ultimately cool is what Im going for so I don't mind a little noise, I can always turn the radio up.
Now that the 6x10 Wellers are mine I thought should actually check to make sure they'd fit a Mini without arches.
It's pretty close but the estate will be a lot lower and on neg camber so I'll be OK.
Moving the wiper motor behind the bulkhead left me with a recess on each flitch so I set about deleting them.
Made a little template.
Transfered it onto the steel and added an extra 4MM around the edge just in case.
Cut the recess out with the angle grinder.
Fitted the plate to check the fit and tack welded it in. These 'U' shaped magnets are great for blind plates because you can use them as a handle when you can't get to them from behind.
And fully welded up.
I also made a start on the plate to sit infront of the wiper motor.
I started beating a dome into the top clear the top of the motor.
Obviously it will sit right up to the top and still needs a but more work but it's going in the right direction.
