pedrobedro
Man at Matalan
- CX near Chesterfield
Lucky it wasn't the fridgeJust watch out for the flaps with magnets , pals cat was off his food then I noticed every time he went to eat he got stuck to the metal food bowl
Stu
Stu
He was a cat that turned up one day , he was being super friendly and hanging out all day then he tried to live in the fridge and repeatedly meowed.Lucky it wasn't the fridge![]()
“Train?” “Cat?” A law unto himself. One-way lock is useless, as he’s learnt how to hook the door backwards and get out anyway.I am more concerned about your use of the plural.
How will you train the cat to know which of the two is entry and which is exit?
I have always wondered how we managed before Newton's brain fart. Evostick on our clogs?There's an open 125mm hole in the wall of my house about 1200mm above the ground with a couple of jumping points for the cat to use. Installed by the previous owner and it used to have a cat flap. The current cat won't use it with the cat flap so it was removed. It still prefers to be let in and out of the door.
Isaac Newton, the chap who invented gravity, is credited with discovering the cat flap.
I’ve been to Lewis and Harris - does it not get a bit, er, draughty with a 5-inch hole in your wall?There's an open 125mm hole in the wall of my house about 1200mm above the ground with a couple of jumping points for the cat to use. Installed by the previous owner and it used to have a cat flap. The current cat won't use it with the cat flap so it was removed. It still prefers to be let in and out of the door.
Cling to the grass so you don't fall off.I have always wondered how we managed before Newton's brain fart. Evostick on our clogs?
Might find out what the Ozzies use, maybe stronger grass roots?Cling to the grass so you don't fall off.
First you have to show why Australia is "down" when it's on a globe in an endless void. Only then can their grass roots be consideredMight find out what the Ozzies use, maybe stronger grass roots?
