ajlelectronics
- Gloucester, England
How is the top constructed, covering sewed to foam?
Three part sandwich. A base material (I use Calico), some sew foam of the required thickness. (I use 6mm) and the vinyl of your choice on top.
This advice varies amongst us, some don't bother tacking, others glue it tight but here is how I do it...
Cut your plate to size remembering the selvage required and give the back just the faintest whiff of spray adhesive just to tack it to the sew foam. Do the same with the base layer and sew around the perimeter as close to the edge as you can. Cut it out and there is your finished piece ready to sew the pattern and then join to the skirt.
Don't you wander at all doing those parallel lines, the seat with loads of lines must be really hard to not wander a bit, I am thinking how easy it is to follow a
straight line with a jigsaw.
Easier on a sewing machine! You can buy pre-quilted vinyls but the selection is smaller than making your own of course. Rule your guide lines with a Chinagraph pencil or Tailors' chalk. The one pictured is highly likely to have been done with a double needle machine, there is no way to get such accuracy with a single needle (in my experience anyway). Use a thicker thread in a contrasting colour for the decoration.
How is the side sewn to the top?
It is sewn inside out. The top piece is known as the "plate" and the surround is the "skirt". To join them, you offer the two edges together, centred according to which end you want the seam and I often staple at this point. Then it is just starting at one end with some overlap and finishing the other end with a similar overlap. The stitching doesn't go right up to the centre line as yet. Pull the two overlaps into position and mark the centre line on both. Staple if you wish and then sew the two ends together along the mark. (I would French seam it here for appearance sake, but that's a guide for another day.) Lay the loose pieces onto the plate and now finish sewing along the seam. Turn inside out and you have joined them. You may want to top stitch (aka felled seam) around the edge, which required the selvage (from seam to material edge) clipped at intervals and around the curves to reduce the bulk.
If you want to do some research, then look for "how to sew a box cushion" which is similar although only one plate of course.
