Well, sort of. Previously compliant set-ups, especially those with RCD protection and pvc cabling, are seldom impacted by new revisions unless or until modification.So my old tin MK Cu with mcbs is ok then - yes I know they aren't covered...
Either of these any good?screwfix or toolstation bg fully populated boards are cheap enough and quality
That's what I dont know. Lolboth will do the job depending how many ways are needed
Either. my thinking an extra spareway or two does no harm.Got no replies last time so asking again.
More details this time.
Which of the two above would be suitable for a garage?
If the RCD is protecting multiple circuits including the lights and it trips it could introduce a falling over hazard!why is an rcbo safer than an rcd with mcb .the only advantage the rcbo has is only one circuit fails on a fault and its easier to fault find. ive only ever tripped my garage supply once in 5 years slicing a cable
if its so important fit an emegency light.. ive fitted a fair few in electrical cupboards in a school i work at
I hadn't replied earlier I went down with a motherload of a cold, viewing but not replying.why is an rcbo safer than an rcd with mcb .the only advantage the rcbo has is only one circuit fails on a fault and its easier to fault find. ive only ever tripped my garage supply once in 5 years slicing a cable
an rcbo is an rcd with built in mcb a seperate rcd and a seperate mcb is just the same and the tripping times and current of each will be identical so makes no odds which you choose for convinienceI hadn't replied earlier I went down with a motherload of a cold, viewing but not replying.
I'm sure I read here or maybe on another site and it was repeated apart from the convenience of RCBO circuit fault finding, in any same give fault a RCBO would trip faster than an MCB?
It's why I said safer.
