8mm thick mild, bevel for a groove butt weld.How thick and what size bevel? An angle grinder would have been my first thought, cubitron discs if you want it to be quicker.
8mm thick mild, bevel for a groove butt weld.If these are practice coupons, as above, what thickness and size of metal are you using?
If the piece is not more than maybe 100mm wide, maybe an abrasive chop saw or a slow-speed metal cutting saw would do. This one says 119mm capacity: https://www.makitauk.com/product/lw1400.html . You can set the vice at an angle, cut the bevel, get two bevels for the price of one (assuming 45 degree bevel) and just tickle with a grinder to put the land on it. If you are cutting your test pieces out of for example 100 x 20 flat bar, stack two or three togehter when cutting.
Cutting the bevel turns the least amount of material from the raw stock into swarf/sparks (just the width of the blade) so will be quickest - compare with grinding a 45 degree slice off a square edge.
i did the same was easier to cut it with the slitting disc in a hand grinder than take a long time grinding it at an angleI set up my track burner one day one 1/2" thick (13mm) plate, and made the cleanest 45 deg chamfer.
could have used it as a lawnmower blade.....
I have one of those. Does a lovely job, but not for weld prep on thick steel. Biggest chamfer it can do is 3mm.Why not get o:ne of these chamfering tools - I'm told that they are very good:
Yes, I bought one a few months ago.I may well be wrong, but I was under the impression that those pneumatic chamfer thingies used a triangular carbide lathe tool insert and by adjusting the ammount of stick out you could cut up to the length of the insert side. No doubt the wider you go the rate of cutting would have to reduce as I don't expect that their turbines are very powerful.
...I was under the impression that those pneumatic chamfer thingies used a triangular carbide lathe tool insert and by adjusting the amount of stick out you could cut up to the length of the insert side.
I believe you'll run out of power/torque before you get to the max. of the cutter.I had to know so I went into the shop.
The sides of the inserts are 7.5mm long but with the base adjusted all the way up for max depth of cut only about 4.5mm is protruding.
And from that 4.5mm at least 1mm is hiding behind that bottom bearing and can't make contact with the workpiece.
The only way to make deeper cuts would be to mill some material of the base.
