Jelly_Sheffield
Time is an illusion. Lunchtime doubly so.
- Sheffield, UK
My Aga cooker can too, it puts each of the three big ovens on a different phase, so it only needs a 16A circuit rather than 40A.Yes but not this one.
As an aside my Mum's Bosch electric oven could be wired, single, two or three phase.
Without seeing a circuit diagram you can't assume the rectifier design will be happy with a single phase input, because it may actually be combining the output of three (smaller, cheaper) units.If it were a transformer machine, it would not work properly without all three phases. As it is an inverter, it only needs a DC supply (rectified AC supply) of the correct voltage. If the transformer can supply enough power (11kW), the inverter should be happy. As it stands, the transformer is not big enough.
Jack
