Nice work. How on earth do you go about measuring / figuring out the bend locations for that?An awkward handrail,steep and variable radius,25solid round.View attachment 465038View attachment 465039View attachment 465040View attachment 465041View attachment 465042View attachment 465043View attachment 465044View attachment 465045View attachment 465046
Great Idea. More work, but he only addition I can visualise would a sleeve with bearings over the horizontal stem, which would work for older large lathes with "threaded" mounts. The chuck jaws could be clamped onto the sleeve making the chuck easier to spin off, or on. Here's a rough sketch............................................... but this should work as a prototype.
That’s not too bad,the hard part is estimating,I quoted £1080+vat,it came out £1284+ vat,so I’ll probably meet them half way.Nice work. How on earth do you go about measuring / figuring out the bend locations for that?
Mr. @pressbrake1 has already recommended this to me. When i get the plasma working and make Mk2 I will make the bar rotate.Great Idea. More work, but he only addition I can visualise would a sleeve with bearings over the horizontal stem, which would work for older large lathes with "threaded" mounts. The chuck jaws could be clamped onto the sleeve making the chuck easier to spin off, or on. Here's a rough sketch
Following on from this they moved their first bale of straw last week and worked well. What was normally a 45 minutes of faff was down to about 10 minutes if you discount the slow travel to the stable as the horse decided it tasted rather good.One half of the bale spike
Just a quick bodge with the holes being plasma cut out of my DIY pallet fork headstock. The weld in bushes go through a 10mm plate on the front, the narrow side of a 80x40x3mm RHS and then another 10mm plate holding on the quick attach hooks, the bush is also welded on one side to the 20mm thick hook that forms part of the quick attach mechanism.
Only going to be used to pick up a handful of 4ft round hay bales and 8x4x4ft straw bales a year so doesn't need to be particularly strong. The headstock is slowly being used, abused and repaired but it's comfortable lifting 2t pallets.
Change to wood pellet bedding!Following on from this they moved their first bale of straw last week and worked well. What was normally a 45 minutes of faff was down to about 10 minutes if you discount the slow travel to the stable as the horse decided it tasted rather good.
Still not trivial but I am trying to slot a 8x4x4ft bale through a 6x4ft wide gap. Basically push bale in as far as possible then wedge in place with 6x2s and then swing JCB around to "precisely" push it into place.
Edit: oh and to get it in the bale has to be at 45° to the vertical
Threads on the drain plug normally 1/4" or 3/8" bsp. They are loctited in so a bit of heat is needed to unscrew them.Sort of made it but connected these to together. Bit harder to tune up than the smaller ones i had a while ago. and they were different makes. Saying that these have different motors and motor pulley.
still all good now, Just need a shed over them.
Today i thought be good if i can fit the drain to the front, just need to find the thread sized and fittings and use a copper pipe to taps. should work. Making it easier than pulling them out every other day to drain the tanks.
I reckon there about the same price as straw for us, but far less volume to repurpose after use. We cant-use shavings or sawdust as it ruins alpaca fleece, pellets don't. But on cost comparison pellets cheaper by the pallet, than shavings and as you buy them as fuel no 20% vatFar more expensive, well at least shavings even with free sawdust from the local woodyard.
That puppy must have felt very relieved after dropping that out his back end .Only pull the first wellie half way off so you are still able to stand inside the calf covering bit , put that foot on the muddy jack and fully remove the other boot . having obviously got a pair of easy to put on croc's handy close by on clean ground .Far superior to the one I made. Same problem though. Dirty wellies, pull off one using the other foot to hold it down. Now you have dirt on the platform. How do you pull off the other boot without getting your sock dirty?
Or am I wrong as usual?
