markherbert
New Member
- London
Hello. First post here, long time "lurker"
I have a Selespeed "robot" here leaking and I believe the problem to be the rust on the vertical plunger/piston.
The geometry is quite simple, and I could make a technical drawing no problem.
I've also considered seeing if the shaft could be repaired however I think it would cost more than having one made, but correct me if I'm wrong. The shaft is 11mm diameter and about 40mm long
I'd like someone to machine a batch of them, my questions are as follows.
Material:
The end of this shaft is essentially open to the elements. The original seems be steel with plating (chrome/nickel??)
Would it be possible to make this shaft out of stainless, would a good enough surface finish be possible? Just thinking that would be simpler than having a shaft made undersized then chroming and polishing.
Cost:
If I was going with stainless, and wanted say 5 of these made, what sort of cost could I be looking at? Would be quite tight tolerances due to the shaft size and also surface finish would be important (especially if not plating)
And finally does anyone have any recommendations for a company or individual to make some of these for me
Material:
Cost:
